I have made a blue graphic box. Inserted text (as graphics) and pics. So, it’s a blue column/box with a three pics and three graphic text descriptions under each.
When I preview in browser, non of the text shows up. The boxes they are in show up, but no text.
Hi Robert I can not tell what it is from the description.
it could be A dozen things.
I suspect everyone could do with a little bit more information or view the page in some way or even better if you could upload the freeway page for people to download then that will certainly help work out what’s gone wrong.
Well, I manged to fix it using layers, for now. And I’m under a tight deadline, so as long as this works for now. I’ll stick with it.
Basically, I had an html box that I added color to and inserted three images and then inserted their descriptions underneath each image in separate html boxes. Took some fiddling to get them all lined up, but it looked OK in the FW doc, but when reviewed in a browser, the white box with the text in it shows up but the text in the box doesn’t.
