If you have the example then you should also have the unitip.js and unitip.css files which are referenced in the Head of the Document. Page>HTML Markup before end head.
The actual tooltip text is simply added in the Alt text section of the inspector for the image.
Thats all there is to. You can use an action (Upload Stuff or Extra Resources) to get the js and css files to the server or FTP them just remember to adjust the path in the Page>HTML Markup section.
In this example the first two faces top left back row - I have applied a graphic for each but as you see the tool tip disappears when I roll over them.
What I’m trying to achieve is a tool tip on rollover on each face which displays their name then a click to bring user to a page of info about the person.
I have a Map area and link applied to first two faces top left.
Your problem is going to be that you really need to draw a graphic box over each face with the Alt text applied to it - but your image scrolls so you cannot keep the graphic box with each face. Hmmmm!
I finally got round to having a look at the tool-tip file you sent me and am happy to report that I have a working example with all the tooltip markers in place!. Just a couple of questions:
I Noticed that your page example (sent to me) output was set to XHTML 1.0 Transitional. When I published the page it was set in the Document Setup (in my Freeway) to output as HTML 4.01 Transitional. Result being all the rollover gifs on the faces were showing outline edge and alt text within and a question Mark in each when I uploaded. Can you explain the XHTML / HTML usage please.
also:
In the ‘untip.css’ file is it possible to slightly reduce the text size and perhaps the colour of the tooltip text - I tried but it didn’t work.
All in all I am very happy with the result so far. I hope to get this project live in the not too distant future. The original photo was given to me over 10 years ago to scan original and stitch back. I lost the file and just found it recently. I am in the photo - it was taken 44 years ago! I was a 1st year pupil. Now I want to upload it and have pupils send back info as to what happened in their lives! I will let you know when it is live.
Not sure that matters but you can change individual pages within FW in the inspector. Page Inspector with nothing selected on the page, 3rd Tab 1st selector HTML:
Can you post a link - or email it to me if you dont want to share with the world.
As far as modding the CSS goes - yes that should be doable. What size/colour do you want?
I am also assuming that you have changed the links to the images in your version of the unitip.css file to point to the unitip images on your server (and not mine!)
