mcolairo
(mcolairo)
September 28, 2011, 7:31pm
1
Hi all,
Not sure if I am doing anything wrong here, but I am trying to use the transition FX action and when setting my graphic to "initially hidden* and then to slide up or down on mouseover nothing happens?
I basically want to create this effect used on the image squares within this website http://www.ovefelt.se/
Could somebody explain where I am groing wrong, or if there is an easier way, or a tutorial video for this.
Many thanks
Have a look at http://www.deltadesign.co/fw_examples/slcaption.html
This uses a pure CSS solution - no actions or javascript - I got it from Chris Coyier over at http://css-tricks.com/
http://css-tricks.com/8856-slide-in-image-captions/
It does require a bit of coding/CSS
But post a link to your own page so that we can have a look.
Here is an example with screenshot of the action interface.
http://www.deltadesign.co/fw_examples/fx-slideup.html
mcolairo
(mcolairo)
October 3, 2011, 12:56pm
4
Hi Dave, That is exactly what i want to do! I have replicated your diagram, but still nothing happens! the image and the text box just both appear as they are when the page loads. There isnt an extra action i am missing here is there?
Really frustrating.
Thanks for your help
No extra action(s)!
Are all your image/text containers layered items? If they aren’t then try them layered.
mcolairo
(mcolairo)
October 5, 2011, 9:53am
6
Thanks! Got it working now Dave!
I have one more question, its not essential but i was wondering if the sliding text box could be semi transparent? If so how would this be produced.
Many thanks for all your help.
You mean like this
Select your text container which is currently a graphic item being output as a Gif.
Change it to output as a png, millions of colours and set the opacity slider (Paintbrush tab) to a value that suits.
Thanks Dave
If you wanted to go back on the mouse out is there a way of doing it ?
i.e mouse over … appears so on the mouse out it hides or fades back
Stu
mcolairo
(mcolairo)
October 5, 2011, 7:46pm
9
Cracking!
All done now, thanks again Dave.
Mart
i.e mouse over …. appears so on the mouse out it hides or fades back
Not with the action in its current form.
You could hack it about as in http://www.deltadesign.co/fw_examples/fx-slideuptest.html
