Tried to put animation gif into site
Tried to put animation gif into site and it comes up with flashing garbage. What do I do?
What do I do?
Tell us where to see the problem page…?
It should be fine. So it might help if we could see your current problem.
k
http://www.2themancave.com/
It should be a flashing arrow
and it comes up flashing garbage.
vic
Did you try importing it as a “Pass-Through” graphic?
(File > Import > Select Graphic Item > Check “Pass-Through > Click OK”)
Curious. Is this a box-model page construction of some sort? Could
you try it in a more ‘regular’ Freeway page structure? I.e. just drop
it onto a normal page?
k
Pass-Thru graphic worked. Thanks
Cool, that’s good news. Could you also test it by dropping the
graphic into a regular (non-inline) layout, if that’s how you’re
currently working? I’m wondering if there’s an issue there, and
you’re best placed to see if this is relevant or not.
k
The graphic was placed on a regular part of the layout.
It just looks grid based.
