Two questions: Creating Flash animations and export them as animated GIF ?
For some banners (text animations, moving images, etc. - nothing complex) I’m looking for an easy-to-use Flash authoring software that is not as pricy as Adobe’s original products.
Also I would need to export these animations as animated GIFs later. While I found some converters for Windows, nothing for OS X (at least what appeared suited to me)… could the pro version of Quicktime be a possible solution ?
Looking forward your recommendations. Thank you :slight_smile:
Take a look at this thread:
http://www.freewaytalk.net/thread/view/38557
Sounds like just the ticket. As for QuicktimePro…unfortunately the Flash capabilities are no longer available, unless you have an older (6) version of Quicktime.
Walt… My reply seems to have taken on a new thread. I answered from the web site as always.
Why does this happen?
This can happen if the original message did not have a properly coded
message ID. I have seen this happen a few times over the past few
weeks, and cannot see a common reason. It’s a bug in the mail parser
for this site, I believe.
Some people have said that Bannerzest Rakuten DX — Rakuten DX works for them and there are also various offerings from Vertical Moon http://www.verticalmoon.com/
Different feature sets - may meet your needs.
