Two Questions
Intaglio has strangely started opening all dialogs directly behind the drawing panel. For example, when I select “Rotate…” from the Object menu, the rotate option dialog opens behind my drawing. It doesn’t seem to matter where I move the drawing window. There’s gotta be an easy fix, but I can’t find what it might be.
Also, I bought via one of the Mac bundles, and want to upgrade from 2.9.5a to 3.x, but can’t get to the upgrade panel. I can’t afford the full program price. Is there some trick to getting to the upgrade program?
Thanks!
Intaglio mailing list
