This is where the error is coming from. You are using array notation
(square brackets) but you have a bare string inside the brackets.
That needs to be in quotes, so put $(f[‘Number_of Guests’] in there.
Also, look closely – you have a space in there as well, so it’s not
going to work on the form side for that reason either. So you really
need to rename your form field to remove the space, probably
‘Number_of_Guests’.
How did you generate the form handler code? Is this from Forms To Go
or similar?
On Apr 14, 2008, at 9:22 AM, James Wilkinson wrote:
This is easiforms from Mike B… and I just created my form normally
and added the action to the elements
James
‘Number_of_Guests’.
or similar?
It’s always been true, a variable name must be a single word. This is
true in any language I have ever used. When you name a form field in
Freeway, there is no coercion to do the right thing the way there is
for IDs. Perhaps this should be a feature request…
On Apr 14, 2008, at 9:54 AM, James Wilkinson wrote:
Ok - so putting the “_” between the words did it - but is this
something new? I don’t remember needing to do that before…
I completely agree - there should be an error pop-up or something to
say that - but it does seem restrictive when you see menu elements on
other sites with spaces - FW should do this for us automagically.
It’s why we use a WYSIWYG app, right?
What does a form element’s name have to do with its value?
The issue here is with the name of the field, which becomes a key in
the POST or GET request array sent to the server by your browser.
In the case of a popup with multiple values, each option of the
select element can have a value that contains spaces. It’s just the
name of the form element that we are concerned with here. That can’t
have any spaces in it if you plan to process it on the server at some
point.
In a menu list form element, you only have the option for name as the
values are the options people chose when viewing the form online.
This name is what is returned to the form receiver with it’s
corresponding value that was chosen. Asking FW to encode the spaces
that people will most certainly use (like I did) isn’t a lot to ask?
Right?
So the receiver sees this - or should…
Date: May 1-4, 2008
Hotel: 2 Star - 2 Nights - € 225
Number of Guests: 4
HI,
Spaces are allowed in form element names. However if, as in some cases, you use the id atribute instaed of a name, you will run into problems. It is good practice to avoid them at all costs because of the trouble they can cause.
The problem comes down to when the POST or GET data is retrieved at the other end. In James’ example, you do indeed need to put the name in quotes.
$f[‘Number_of Guests’]
and this should work as long as there is a value in the array $f for the key “Number_of Guests”.
However, if you want to use the other method of grabbing the same value:
$f.Number_of Guests
then clearly you are heading for trouble as PHP will be looking for the equivalent of:
Ok - so where is the issue being generated from then? Is it the
easiform action or FW who is the culprit??? I’m thoroughly
confused… All I’m trying to do is have a form element with spaces
in its name and use the easiform action…
I think you are trying to use spaces in the value, the name of the
field is known (or cared about, anyway) only to the server. Nobody
here has said you couldn’t use spaces in your values. There’s nothing
magical about that.
Do you have another form somewhere that has the EasiForm action
applied, and that is not running in test mode? Because it would be
trivial to pop a new field in there that contained a euro mark and
see if you could see the field properly. That would remove the
EasiForm action from the list of possible problems.
I do not have another site running easiform - this is my first one…
and yes, I know that in the values you can have spaces… it’s the
name of the element. The name is super important as it tells the
receiver of the form info, what was chosen in the form. In my case:
Date: May 1 - 4, 2008
Hotel: 2 Star - 2-Night - €265
Number of Guests: 4
Telephone: 555-555-5555
etc.
otherwise if I did not assign a name to an element, the receiver
would get:
item1: May 1-4, 2008
item1a: 2 Star - 2-Night - €265
item1b: 4
item1c: John Smith
easiForm will remove the underslash from the variable name, so
‘number_of_guests’ set to a value of 10 will show in the email that
you receive as Number of guests: 10
If you are using the easiForm actions the you would just enter
‘number_of_guests’ into the ‘Name’ field in the inspector for the
element and easiForm will do the rest.
Mike
Number of Guests: 4
etc.
would get:
item1b: 4
item1c: John Smith
Oh and yes, ‘number_of_guests’ without the quotes!
On Apr 14, 2008, at 8:35 PM, Mike B wrote:
James,
Most likely the issue is that your demo-alert box is appearing before
the opening html tag, so the page is really really invalid. That
might be putting Safari off.
Try this on your server app if the domain isn’t registered:
