I’d just like to clarify a few things before people get too concerned about upgrading:
The issues raised only affect a very small number of existing sites. Freeway will always create a backup of sites created in older versions so your work will never be lost. If you do have any problems, please report them to support(a)softpress.com so we can get you a solution as soon as possible.
Carla and TomP, please send a document you’re having problems with (the smaller the better) to us at support(a)softpress.com. Please provide as much information as possible (system information, where you’re saving to, etc.)
meee, Freeway 6 is $59.99 to upgrade from 5.5, $109.99 from 5. Enter your serial number in this page and click the Upgrade button to see your price: http://www.softpress.com/pro-upgrade/
Lee, you’ve already been answered but for anyone else wondering the same thing: as Dave said, to run both 5.5 and 6 at the same time you need to rename 5.5 in your applications folder before installing 6. Don’t worry if you haven’t, you can always download the latest version of 5.5 here: http://www.softpress.com/kb/questions/300/
Remember, there is a trial you can use to try out your existing sites. A backup of your documents will be saved automatically when you open them in 6. It’s very unlikely that you’ll have any problems. If you do, they should be easily resolved by either updating Actions, or contacting us at support(a)softpress.com.
Thanks!
Joe Billings
Managing Director
T: +44 1993 882588
E: email@hidden
Hi Joe
and everyone. I have sent you my error message yesterdays. There is no doc to send you as my Freeway 6 will not open anything, whether an existing site nor a new doc…
I tried to register my serial # and that too produced and internal softpress error which I also sent to you
so I will wait here for your reply
thanks
Carla
I just checked my Application folder and my old copy of FWP is labeled, “Freeway 5.5 Pro.app”, which apparently was assigned by the installer. Does that mean no renaming is necessary?
Raven, I have 5.5 and 6 running side by side and I didn’t rename anything, Justin is saying the same above (I think). I would imagine it would be the same for you.
Simon
Er, there is the obvious use of sub-folders to separate version types.
I am happy to report that I tried again to register upgrade and it worked… I have had a few crashes though. but I will update all actions before I open any site. I think that is the best thing to do.
IIf I may respond, as I had to do the same
go to your freeway pro 5.5 application and open it
that one is labeled fw5.5
the new fw6 is labeled freeway pro
you can download again here
