Yesterday I spent the day cleaning out duplicate / triplicate files. With a replacement of a HDD and then replacement of the MBP I had been “shoving things” on to my externals so that I would not loose them with all.
It was time to clean.
In addition erased a bunch of files - as thought to be simple search files that would be regenerated on publish / upload.
I am now getting this error in uploading the site with corrections / additions.
any suggestions would be appreciated… Thank you so much for your help.
Julie
On Oct 15, 2011, at 10:01 PM, Julie Maxwell wrote:
Good evening,
I presume you can see the file in the Site folder.
Try using Disk Utility to repair permissions on your HD. Don’t use repair for now. Then reboot and see if the FTP program can find and upload the files.
If FTP fails again go look at the files and make sure they are not aliases pointing elsewhere or corrupted files with zero size.
If FTP still fails copy the site folder to your desktop by holding down on Option when you do the drag and drop copy. Do a Get Info on original Site Folder and the copied one. Are they the same size and have the same number of files?
And by the way using Disk Utility can tell you if you have an impending disaster. When you use Disk Utility believe what it tells you.
Dale Josephson
On Oct 16, 2011, at Sunday10:53 AM, Julie Maxwell wrote:
I removed the SS actions - and the error went away but now I have this one:
Julie
Good evening,
Dale Josephson
Julie
Good evening,
