Here are three emails that were rejected (said I couldn’t do it), I think they went in with my gmail addy!
I feel I’m stuck in a mess, I’ve no apostrophes in any of my Resource files or the Media file which holds all my images in Sweater Images.
My site has run for ages with apostrophes in the past. Anyway I now seem to have my Resource Folder not register in Freeway.
Carolyn
HI Simon, thanks for replying. I’m trying to follow all the suggestions.
It sounds like you’re renaming the files inside your Resources folder,
Yes I am but also I renamed everything in Freeway too (the main images and the pop up windows too.
rather than renaming the files in Freeway. While this would work once
if uploading with Transmit, the files using the apostrophe will be
written again the next time you publish from Freeway.
If this is the case, what you may need to do is rename your items in
Freeway to remove the apostrophes, probably a good idea to remove your
Resources folder from your server and in your site folder (using the
Finder) as well, just to remove duplicate files.
I removed the Resources folder from the server (a couple of times and re uploaded) but are you saying I should remove the Resources folder from my finder, check everything in Freeway and re publish?
After removing the
apostrophes from Freeway, you should be able to upload and all the
files and links will be written to your site correctly.
I’ll give that a try, thanks.
Hi Simon… again,
I get a resources window with ‘edit’ in it and when I look down the list. all the pop up window images are ‘missing’. I spent a lot of time setting them up… now what. Should I go to the server and get back what I uploaded yesterday after all my corrections (apostrophies and capitals changed)?
Hi Again Simon,
I just removed my Resources folder from the finder and now cannot seem to upload my site from Freeway as I keep getting told that the resouces could not be found! What do I do now. The site is still there but I’ve no resources. What does this mean?
thanks, Carolyn
