Hi I am not sure how to put in my shop URL, I have a home page then - shop button and then in shop page is 5 shop pages to go to.
I have tried many options and can not get my mals e cart working with freeway, please advise… This is the message I get I have read the instructions on freeway manual page 410, I have tried several URL options…
Andrina
FREEWAY CONFIG
The shopping cart will automatically attempt to load a new configuration file when you change your settings in Freeway.
Sorry, it was not possible to load your new configuration: It was not possible to connect to your webserver at:
Hi Andrina,
The freeway Shop Actions create a small configuration file that holds some of the styling information for your Mals shopping cart. This file (malsettings.cfg) is created by the Actions and should be uploaded automatically to your server when you upload the rest of your site.
Sometimes the Mals can’t locate this file and you’ll need to log into your admin account over at Mals and click on cart setup and Freeway settings (lower right hand corner of the screen). This will give you the URL of where it thinks the configuration file is located. Click on the link displayed and change the URL to your shopping cart and hopefully the issue should get resolved.
It may be worth using an FTP tool (like Cyberduck http://cyberduck.ch/) to log into your FTP account and look for the malsettings.cfg file. If you can’t locate it you need to upload it to the server. If you can find it then make a note of the file location and use this to update the Mals admin area with the correct URL.
have downloaded cyber duck, and did Quick connect to my website, wasn’t sure what the other options were for, it showed me a list of files in my website, I can see malsettings.cfg - when i click on it this is what i see: ftp://email@hidden/malsettings.cfg file:/Users/andrinasmylie/Downloads/malsettings.cfg I did try pasting this ftp: in the mals settings, and it did not work.
When I search for malsettings.cfg in finder it shows it in my WEB freeway file.
I have been getting help from delta dave on this, I have also updated my freeway. and still can not get it working.
