Thank you. I am sure that you are correct and that the fault is mine.
However I am rather ‘at sea’ now as I see that the Freeway action
includes the line in the Action Panel that reads thus:
“Perform POST on PHP easiForm variables” which is the only reference
to ‘post’ and there is no option I can find in any part of the action
dialogue boxes in Freeway to allow me to do what you say… as you
say, I would have thought this would happen along with the other
things the action does. There is no mention of it in the tutorial that
I can see.
Nor did I understand what Todd Brown advised me to do which was to
“Be sure that you are using a file extension in your
“action=xxxxx.php” line.”
I can’t se anywhere where I am asked to do that, and I have looked
inside the easiForm_config.php file to check in case I’m missing
something.
I have created a simple no frills contact form which is now giving
another error message thus:
"Warning, your form is using a Freeway Action to include ‘easiForm’
but it appears the ‘easiForm_config.php’ script has not been uploaded
to the form directory, you will need to upload the
‘easiForm_config.php’ file to correct this error.
The trouble is the file is there on the server-right directory,
everything.
I will contact Mike and ask if he can shed any light.
Thank you again for your help.
Martin
On 21 Jan 2010, at 16:30, David Owen wrote:
There is no action to Post the form to the script.
<form action="url-to-my-script.php" method="post">
You would normally put this is the form set-up in Freeway. Or the
action should do this for you. Why not contact Mike for Advice on
how to do this with the script?David
On 21 Jan 2010, at 15:41, Martin Bullivant wrote:
But the submit button doesn’t make anything happen
tutorials mailing list
Martin Bullivant
Director
