Try something simpler first, just to get the thing working at all.
Make a new Freeway document, with one page in it (with the filename
index.html and the title Hello World). Put a big blotch of red in the
middle of the page and try uploading it to your test server.
Your hosting provider will have given you the following:
login
password
domain or machine name
If you use Fetch or another FTP application to log in to that domain
or machine name with those credentials (and your login is successful
– meaning that the username and password are correctly entered, case
sensitive characters and all) then you should be dropped into a
default “home” folder for your account.
Most likely, that will be at least one directory “above” your Web
root folder.
That Web root folder, where you put your files to be served, will be
named some flavor of “htdocs”, “httpdocs”, “web/public”, something
like that, specific to your hosting provider. If you can’t spot it by
name or intuition, ask your hosting provider or search their help
system.
Anything that is to be publicly available must be put in that Web
root folder or another subfolder within it, or it won’t be served by
the Web server.
Once you have figured out the path to your root folder, then you can
move your files into the proper place. Test in a browser, and see if
your big red splotch is there.
Once you have it working in Fetch or Transmit or Cyberduck or
whatever app you want to use, transferring those settings to Freeway
will be completely logical. In the Upload dialog, Server will be the
name of the server, like ftp.yourhost.com or www.yourhost.com,
depending on the setup there. Directory will be the path to your
actual Web root, like ‘htdocs’ or ‘domains/yourdomain/web/public’.
User name and password are the exact username and password that your
host gave you (copy and paste recommended). If Passive does not work,
un-check it, and vice-versa.
On Apr 5, 2008, at 12:26 PM, Karen wrote:
Thank you for your help… I recreated my whole website but
wanted to make sure there wouldn’t be any problems so I also made a
test site - both were created the same way. Now since I already
have my website up using Front Page for Mac I don’t want to
override it till I know the Freeway site is working correctly.
Hence, the test site
Followed all the directions for uploading, went to my site on my
browser, and plugged in the test page url… nothing there…
since I have an online store, I need for all my products to be
there… nothing was… no errors either… nothing said it
was not uploaded… in fact I saw a progress bar uploading it…
I opened Fetch to see what I needed to delete and it was not there.
Then I uploaded via Fetch the whole folder that I put the test site
into… that did upload and I saw my test pages with links to
the Mals shopping cart. I hit the add to cart button, got the
message to Reload and then it said Error - link verification …
needless to say, with working several months and recreating my
website with over 500 products, I am at a loss why its not
working… I deleted the Test folder via Fetch and am back to
staring at the screen trying to figure out where to go from here.
Suggestions?
