I’m having issues with getting the RSS feed from Google Blogger showing up on my site. I’ve added the _cache folder to the website public_html folder where the others go and set permissions for user,group,and world to have full access. The page the blog is on ends in .php and I’ve set the time to 0 in the action settings. I’ve also validated the RSS feed (and not the Atom one that Blogger also uses) Here is the RSS feed address for the blog http://systemaidsolutions.blogspot.com/feeds/posts/default?alt=rss My website is here www.intothev01d.com and the error I’m getting is XML error: mismatched tag at line 1. If anyone could help I’d really appreciate it. Thanks in advance.
The request for a non-atom feed seems to be falling on deaf ears at Blogger, because this is definitely in Atom format. I am not sure what you can do about this, either.
Yea I just looked at the code there and couldn’t see anything about an RSS version and it definitely says Atom 1.0 right there in the first line. It even validates as an RSS feed at the site which is weird. I just tried Feedburner and that too now just uses Atom 1.0. Is there anything similar to Blogger that I could use to create a blog that would integrate with ReadFeed? I think it would work great if I can get something that will use RSS that way I can style it with Freeway and integrate to the website.
