Matt McArdle downloaded a fresh copy of lightbox. I’ve just done the same and entered the path: fileLoadingImage: ‘/webyep-system/program/opt/lightbox/images/loading.gif’,
fileBottomNavCloseImage: ‘/webyep-system/program/opt/lightbox/images/close.gif’,
It seems to be since I downloaded a fresh copy from huddletogether website and used the same path that it is working. Not sure why this would make a difference as I’m sure the files were exactly the same.
I have just read the other thread that you linked to where Matt’s problem was the text encoding of the edited JS file.
You may have had exactly the same problem without realising.
What text editor did you use to edit the JS file? I can see that TextEdit could mess this up whereas something like TextWrangler or BBEdit is less likely to.
I seem to be having the same issues with LightBox again. I’m testing a gallery page for a new site on a folder here:
I’ve installed a fresh copy of Lightbox but it’s not working. I’ve tried going back through earlier advice on the forum but no luck. Uploading a fresh copy of Lightbox seemed to do the trick last time but not this time. I’ve also changed Coda’s preferences to Unicode UTF-8 and checked the URL link to the lightbox.js file to make sure the permissions are ok but I can’t figure out what else I need to do to make Lightbox work.
Ok I’ve cracked it. Using Coda remotely to change the code was the best and quickest way to work out what was going on!
Saves much more time than changing stuff on the desktop and then uploading!
