I need a web site designed in Freeway. Looking for some designer who can make a simple but well designed site.
Roberto Alva
Roberto Alva
What exactly are you after Roberto - please be more specific in order for people to assertain what it is you actually want to achieve!
Worm
thank you…
I too have responded but did not get clear direction of what he wanted.
order for people to assertain what it is you actually want to achieve!Worm
Hi,
I too would be interested… could you please specify you needs? Also, do you have a email address for potential designers to get in touch with you?
I have an existing page but would like to redo and make it cleaner
while I don’t want to lose the old I’d like to link to is so I can go
forward with a cleaner site
I can expound more to anyone who’s interested
On Sep 3, 2008, at 9:55 AM, Fergus T wrote:
Hi,
touch with you?
You can always setup a new separate folder for the redone pages in your home directory at your hosting site. Then make the links manually in the old page to the new pages. Both old and new will exist and be accessible.
Sorry, but what does that mean?
best wishes,
Paul Bradforth
chuck
that is what I am currently doing
but my sites are a mishmash of freeway and dreamweaver and freeway
raises hell everyting we upload wich is quite often.
a clean sweep would be so nice
dale d
forward with a cleaner siteYou can always setup a new separate folder for the redone pages in
Paul
lo siento
I didn’t make myself clear.
I guess the best way to explain is for you to go to
www.nicasurf.com and surf your way to nicasurf.com/surfupdate
when I say cleaner I mean the same amount of information but presented
in a more organized and findable way.
dale d
forward with a cleaner siteSorry, but what does that mean?
best wishes,
Paul Bradforth
As long as the directory you publish the Freeway pages into does not contain any other pages (such as from Dreamweaver) you should not have a problem.
If what you really need to do is recreate your entire site, then do that in whatever application you intend to use be it Freeway or others, create a test folder on your host and don’t link to outside pages at all until you are comfortable with the new pages. Once you are confident in your new pages simply remove all the old current Freeway pages (and non) completely from your site with an FTP application and move all the contents of your test folder to your home directory.
Put the two sets of pages in different folders and just link across
from one to the other when needed. No need for hellraising.
k
My address is email@hidden. (does not appear?)
I’ll try to be more specific but if you send me some link to portfolio will help.
Coming back soon wit the details
Roberto
you can not just type an email ad into this forum… try posting it again but breaking it up with brackets ie. yourname(@)yourdomain(.)com
Roberto, wouldn’t it be easier to just add your email address to your member info?
