I that is one thing I am having an issue w is the preschool page…
any suggestions how to correct…
do you know what page the program menu runs into the text?
DO you mean the mission? I need to make the font smaller … but then
it is not uniform w the others… also … anyone w any suggestions on
this?
There is a rollover on the rt when it says NYS food… that is a pop
up / rollover b/c we need the food services description.
Thank you!.. I will check into these all.
Julie
On Oct 22, 2009, at 4:09 PM, Robert B wrote:
Julie…
A few things.
The Infant page: Miss Dorall needs to flush left. Looks like there
might be a space there.
Preschool page: Text runs together over the slideshow
Programs drop down menu sometimes runs into text on page.
About Us: Text runs together over the ladybug. And there’s some odd
rollover thing going on there, too. Can’t quite figure it out.
Preschool page: Is the text that starts, “Our field trips…” and the list under it in the same text box? It should be to avoid the overlapping text.
About Us page: If you put the Child and Adult Care Food Program link in the same box as the text above it and then put a little less space between all those sections of text, it should fix that overlap problem.
To have your Grassroots page open in a new window, highlight the text in Freeway, right click and go down to Hyperlink. In the box marked Target choose _blank from the popup menu.
I will work
On those suggestions.
The mission on about us … Is that the txt going over the grass? Will
it be ok to have that a slightly smaller font for spacing porposes?
Sent from my iPhone
On Oct 22, 2009, at 17:56, Robert B email@hidden wrote:
Julie…
overlapping text.
problem.
No, not the Mission Statement (although it comes very close to the grass). The text on the right side. The line that starts, “We…” and the link text below it.
How did you set up that grass at the bottom? Is it in a layer (green outline) box? If it were in an html box, it might move down with the rest of the text if the text gets enlarged.
It’s a graphic box… But can make it into HTML by putting a graphic
box in the HTML like we do w the lightbox… Would that work?
Ok I will work on spacing
With the shift return to make that area a bit more condensed…
Thank you
J:)
Sent from my iPhone
It appears that when you constructed these pages you did not allow correctly for the margins and as a result the right hand side of all the text has been truncated in the PDF.
Also a first line indent looks very strange on paras with only 2 lines.
I did not do that newsletter… the daycare did… but I have it in a
doc format so i can adjust it… so what do I need to do?
J:)
On Oct 22, 2009, at 8:06 PM, DeltaDave wrote:
Another point - about your Newsletter.
lines.
