Can rollovers be edited in web yep?
I don’t think so. I thought WebYeb could only edit text and single images that sit right next to the text!
And I wouldn’t think that this has anything to do with FW. You could also check out the WebYeb forum. (http://www.obdev.at/forums/index.html)
WebYep, can, with a little bit of pushing edit just about anything on
the page.
I think Max has actually done this here:
http://www.freewaytalk.net/thread/view/14919#m_14919
David Owen ::
Freeway Friendly Web Hosting and Domains
Can WebYep be used with the accordian effect? I’ve used this script in a site and now the client’s asking if they can edit the page themselves.
Yes. Put your WebYep objects inside the div that will slide. Simple as that.
Hi Neil,
yes it is possible, I have used webyep elements successfully in an accordion menu for a client. Here’s an example:
http://www.pixelarte.co.uk/sitemenu/page1.php
Richard
