Cheers!
Hi! I am a lurker, building a site for the first time. I just had to chime in and thank you all for your posts and insights. I have learned so much just following threads such as this one, and by the way, I really like the site, grassrootsweb!
Frank
On Feb 24, 2011, at 8:51 AM, Rice Martin wrote:
For what it’s worth, I think that having the background across the entire browser window looks a zillion times better. The impact is much greater. Also, I don’t know if all that brown is supposed to be underground, that is, where the grass roots go and grow, but if it is, I never realized that until I took a look at the full-screen background. If you didn’t mean that signification, it’s really not a bad one at all, given the site’s name.
Just my own aesthetic point of view.
Martin
Signal Mountain, TN
On Feb 23, 2011, at 10:40 PM, Julie Maxwell Allen wrote:
Dan,
here is the site with the background you are suggesting.
I used the action full background. I tried it with adding it to the page - but the tiling was off due to the fading of the yellow on top - you could see a definite line. maybe I shouldn’t gradient - but I do like that look…
the only issue I am seeing - and maybe I am doing something wrong - but since the header is so dictated by positioning with the grass - that if the browser causes this to go past the “edges” and you have to scroll, the background stays but all moves out of alignment.
let me know what you think. please. (and everyone else too)
I want to get this done before the html box insert.
http://www.grassrootsweb.net/grw
original:
J
On Feb 23, 2011, at 2:13 PM, Dan J wrote:
The brown background stretched out, I’m 50/50 on it. I think it’s missing something and that might be the graphic stretched out at the top or to tile it using just the grass and the brown.
Here’s a thumbnail of something I saw on another site that was more like what I was thinking.
http://dl.dropbox.com/u/3640378/bramnicholson.jpg
Not including the white background, just the grass tiling and background setting.
As far as your page length issue the browser will only wrap itself around the content that exists and the height of the page in Freeway makes no difference in the browser. You could set it to 1 million and it wouldn’t make a difference. What I typically do is set a floating HTML item at the bottom, layered, and just leave it empty with no color or type settings. Set it to be about 35px from your bottom-most content (not the FW page) and then publish it. If this was an authentic box-model you’d set either padding or margin, but I typically set padding as I haven’t had great success with margin in IE.
Try that and see if it works.
