WebYep Installation
Does the WebYep folder reside in the top level folder or if I am using it in a subfolder - do I move it down to the subfolder? Or does it matter?
I have it in the subfolder, but it doesn’t seem to be working. When I move it to the main folder. I get the same not working behavior.
I see a visible lock for the login, but nothing happens when I click it. I had this working before I started moving things around.
Any suggestions? Thanks.
It can reside in a subfolder or the root folder. If you’re working on a project in a subfolder then you can put the ‘webyep-system’ folder in there and the rest of your template files. That’s how I work on them. Are you using any kind of .htaccess file for the root folder?
I have a video, available for purchase, on installing webyep on my site, just click the link in the signature bar to head over to my store and select premium from the top menu, then look for WebYep E1 which handles installation.
Dan,
Thanks. I have all four of your webyep tutorials and recommend highly for others. But, I didn’t recall any mention of the webyep system location options. I am uploading files to my subfolder and webyep system has also been relocated there. I am using your box model - another great tutorial.
I’ve never done anything with the .htaccess file.
I am getting an error
Fatal error: Call to undefined function webyep_menu() in …
Must be something basic. Thanks
If you want to email me off list I can take a look at it for you.
Okay, sent to your store@ email.
I’ll publish solution if I think it’ll help someone else.
Thanks Dan
It turned out to be that the ‘WebYep Page Init’ action was missing from the page.
Thanks for your help and keep those tutorials coming. Not sure you cover much on the WebYep menu action and I need to learn more about the loop action. Two applications I am working on right now heavily depend on using a menu to access various levels of information.
Keep up the great work Dan. Can’t wait to see your new site.
Jan
Dan,
In the WebYep Tutorial 4, you mention using ActionForge.com Remove Paragraph Tags action. That action is no longer listed. Any other suggestions?
I tried to download something of that same name at http://www.freewayactions.com/product.php?id=beta, but I was unable to unzip it. It’s a .hqx file and stuffit couldn’t handle it.
Suggestions?
I just e-mailed you something about 10 seconds ago. It should fix your issue.
Thank you so much. Too bad they took this action down because you are right - I had noticed the alignment issue with the rich-text items.
You guys really help us along so much. Makes it all possible.
Jan
Well I had talked to Max, the action developer for WebYep, about making that happen by default when using a Rich-Text based item and that never seemed to surface.
Perhaps in a vault somewhere is the secret to making that happen. Regardless I’m glad you got it working and you’re all set.
