Hi!
Is there an easy way that webyep/lightbox can crop the pictures that are on display at at site?
As you can see here: http://www.huddletogether.com/projects/lightbox2/
the pictures here has different size in width and height, but the thumbnails are the same size. I have not found a way to draw an imagebox in freeway and the insert images with different aspect ratios in webyep. If I have two pictures. One 640x480 and the other one 480x640 I would like the thumbnail to be 80x80 for both pictures…Is this possible? As you can see from our site, we had to go for the same sized pictures in order for the thumbs to display in the same size: http://sommersethdesign.no/print.php
Thanks in advance,
Tom
