I have a very serious problem with the menu element. It doesn’t show any of the page elements unless the “page.php” is present in the URL. Here is the site:
Any information will be greatly appreciated. Thanks.
TB
PS- if anyone knows of a way that I can get rid of that annoying “Unauthorized Program Alteration”, please let me know. I have submitted a ticket to ObDev for this. Thanks!
You mentioned that you just have installed the programm WebYep for Freeway, can you explain me where you did this and what you choice was, please? Since I cannot find the download for Freeway5. Only for Dream and rapidweaver.
Many thanks for this fast response, I really appriciate that.
Unfortunately, I do still not understand were I can find the WebYep Freeway actions.
Is it something which I can choose during the installation?
The link you gave me put’s me at the “all about me” page.
Sorry, I am always carefully with installations, probabaly when I just installed it became
claear to me.
The WebYep Actions for Freeway is a commercial product that you (1)
buy from Max by going to http://www.max-izzat.co.uk/actions.php and
then (2) add to Freeway. Note that you also have to buy the WebYep
CMS separately, and that gets uploaded to your web site manually.
I use and like Max’s WebYep Actions. I recommend this approach highly.
I’ve found the upload thing on the site of Max, it is even included in the download package which TB wrote.
But, I still cannot find on the website of Max, where I can download and buy the Freeway action and how I have to add it to Freeway. probably it is explained on teh website of Max and do I not understand it, since English isn’t my native language.
Op 6 sep 2009, om 16:22 heeft Publish Relations het volgende geschreven:
Hello K,
Many thanks too for this explanation.
You buy the WebYep Freeway Action by visiting http://www.max-izzat.co.uk/shop/html and clicking the “Buy this
action” box in the upper-right area of the page.
You install it by dragging the WebYep-Actions.fwactionb and
WebYep-Extras.fwactionb files (these come in the WebYep Actions
package) into Freeway. It is really as simple as that!
Installing the WebYep CMS itself involves using an FTP ‘client’ tool
such as the well-respected Transmit (Transmit 5)
to do the following:
Upload the “webyep-system” folder to the web-root level of your
web space (where Freeway uploads your web site).
Set the permissions of the “data” folder. (In Transmit, select the
“data” folder, choose File > Get Info, and check all the different
Permissions check boxes.)
Edit the “config-inc.php” text file that’s inside the
“webyep-system” folder to change the default editing login name and
password.
Yes many thanks, I have already made a few possitive steps with help of your explanation. I have to wait since the website of the customer is running on my server. I am affraid that it will deliver new problems when I have to change the server location after I have implemented the WebYep.
So this week that website will be moved to the new server and than I will start with the real implementation of it.
Many thanks to all people here who have given me such great advice and support. I will let you all know when it has been implemented succefully.
You can design your site on a test server, and “move” it over once you are ready to go live by opening the “documents” file in the webyep-system/program folder and changing the paths, i.e. from “test/index.php” to “index.php”. Your content will be loaded into your live site, provided that you haven’t changed the names of specific items prior to uploading to your live site’s directory.
Please note that any links that are added using the Rich Text items, etc. might need to be adjusted to accommodate their new location. Best of luck to you.
Many thanks for this explanation as well, but to me it sounds a bit complex to be honest, since I don’t have any knowledge of php etc. Therefore I use Freeway
This week I expect to go live on the real server and than I will try to implement WebYep. I’ll keep this forum updated,
For anyone who doesn’t know and for those people that have been having odd menu problems there is a new version 1.4.3 which tackles a few of the web-yep menu bugs
you can find the release note here
Recently I’ve tried to install CMS on the server of the customer, however, that server has not much space unfortunately. Can anyone tell me how many space Web Yep needs on a server? And how can ypu check the space which is needed for the Freeway webdesign? It looks like that the level of used MB’s written behind the Freeway stored document in Finder isn’t all, is that corrcect?
