thanks! due to the dutch version i couldn’t understand the real meaning (i was looking for a style named MyMenu). there will be an update to complete german version? for now, i’m quiet happy.
so - for example if i wish bullet points. i have to use the extended option again? in the menu styler i can’t choose all styling options …
one more problem (but i dont know if that related to the webyep actions): i can’t get back to the main navigation, when i’m on subpage, which was created with webyep. see: http://www.dddserver.net/demo
click on “leistungen”, then on"serie 300", than back on “leistung” - there is no more the link, you have to go on another page like “impressum”, then you can click again on “leistungen”!
i’ve never noticed this behaviour on other sites (without webyep). any idea?
ahhahhah thats where the confusion is…
what I will do is send you the next update prior to general release to see if it all makes sense…
thanks for pointing the translation mess.
For some reason the original test menus didn’t work but I tried again from scratch and it seemed fine. Not sure what happened there and why it wouldn’t show the correct font.
perhaps one note, as you’re working with webyep too:
if you’re working with the gallery-styles (via freeway style palette) and you’re changing padding/margin/colours or something else entering “extended” in these styles (like i do for layout reasons), you’ll see no change in your browser after uploading - you’ll have to force freeway (under menu "page) for a new publishing first (freeway shows new changes with a bullet in the site/page-palettes), then upload!
