I have a page that uses webyep for my client to enter products <http://www.choco-latte.co.uk/retrosweets.php
. My client has entered about 17 items in to the page and they were
visible, but after sorting a problem on another page all but the first
entry have disappeared. The data is in the data folder but is not
being seen. If I add another entry it starts to number from 2 again
and over writes the data that is there with exactly the same file
names. How can I get WebYep to see the data that is there. I have
asked on the webyep forum but no replies yet, any thoughts, Max?
thanks
Neil
Hi Neil you mentioned you fixed something else first
could you tell me what that was?
What it sounds like is some sort of path or structure change for example if you changed the page name or moved a page into a folder… something like that
but without knowing what you did just before it went wrong the best I can do is guess.
Other things that effect webyep items like this is if you changed an item from non global to global or if you put that item in a loop etc
speak soon max
Hi Max,
I have been in contact with Johannes and he discovered that I had
renamed the block, changed it back and problem solved. Duh!
Neil
something like that
I can do is guess.
speak soon max
