You need to make the blue box an inline container for both to expand.
Draw you green box as an HTML item.
Click inside so that the I-bar (cursor) is flashing and go to
Insert on the menu bar and click HTML Item.
Re-size the HTML Item to be your blue box and add your WebYeb item
as before.
Select your blue box an in the Inspector go to Margin > Custom and
set to Bottom: 10
You should also set you green box so that the middle grab handles are
red expanding state) as previously described.
Your green page will grow to the length required and your blue box
will always be 10 px from the bottom of the green box.
If you want both green and blue boxes to be spaced the same way from a
background page , the same principle applies. Make the background an
HTML container and nest the other boxes inside.
However, if you add other elements inside the background page you are
beginning to construct a ‘box model’ which raises other issues, but
here is a tutorial on this and previous threads about it. Just search
for ‘Box Model’ in FreewayTalk.
HTH Colin
On 23 Jul 2009, at 23:07, twb716 wrote:
Thanks so much, Collin. We’re almost there:
http://www.audicashop.com/test
How can I get the green box to expand with the blue box and always
be 10px from the bottom of the page?
Here is what I am shooting for:
http://www.obdev.at/webyep_demo/demoslot_en4397990948929081/en/counseling.php?WEBYEP_EDIT=no7558
Here is the link to my new test file:
http://www.audicashop.com/test/test2.zip
Thanks again for your help!
