I’m copying text into the WebYep CMS / rich-text editor TinyMCR. All my hard returns are turning into breaks. Forcing me to delete all the breaks and redo the hard returns.
Any ideas how I get around this?
I read a post about this from 2007 and WebYep were going to sort it?
I’ve tried copying the text directly from Freeway and copying the text from FW into textedit in plain text mode.
I get the same results. All the paragraph returns become soft returns or . Meaning if I style the first line of text as a heading, all the text is styled as a heading.
If you want to apply an h1 tag for example on a line with the Webyep text element (with a space before and after the Webyep element) then then you want to use the Return key to start the next line in your FW layout. But this is done in FW before ever using WY through the web to enter any text.
