Bart
(Bart)
March 1, 2012, 9:08am
1
Hi,
Does anyone knows what I have to do to make Spanish characters display correct in a short text with Webyep?
I selected ‘Spanish’ in the stylesheet I made in Freeway.
Best regards,
Bart
Hi Bart have you set the Character set within the config-inc.php file within the webyep-system to match freeway’s generated page…
e.g. like this:
$webyep_sCharset = "utf-8";
Thats if you have chosen utf-8 within your freeway document.
If you do, then it should have the correct characters for Spanish within the webyep areas.
Bart
(Bart)
March 2, 2012, 12:13pm
3
Hi Max,
I hade a look and the charset was set correctly to utf-8.
$webyep_sCharset = “utf-8”;
Any other suggestions?
All special characters for example é, è, ó, ñ,… are displaying wrong (= é, è, ó, ñ,…).
The website is made in 4 different languages so there are many special characters. I only have this problem in the ‘short text’.
Bart
What about to set the encoding of your freeway page to “utf-8”, too?
Bart
(Bart)
March 2, 2012, 1:16pm
5
Hi Thomas,
Under document setup I selected Unicode 5.1 UTF-8.
Bart
Yes - and…?
I just ran a quick test with short text and works like a charm even using “automatic” in Freeway.
Do you have a link to share?
Is this probably a server misconfiguration causing this?
Bart
(Bart)
March 2, 2012, 1:45pm
7
Thomas,
The document setup was already set to UTF.
Here is a link to the website: http://www.cafe-fagot.be/es/calendario.php
You can find an example on the bottom of the page
Bart
but that’s what I see on your page:
Bart
(Bart)
March 2, 2012, 2:05pm
9
Thomas,
Thank you for your help.
I realy don’t understand it. In the document setup I selected UTF-8 and in the config-inc I have put “utf-8”. Is there another place where I have to select this? I only have this problem in the short text.
Bart
double-check your encoding probably in the inspector and have a look what actually is in.
Bart
(Bart)
March 2, 2012, 2:24pm
11
Thomas,
Thank you so much. The encoding was ‘automatic’ in the inspector. I changed it and now it’s looking good.
Thank you (and Max) for helping me with this.
Best regards,
Bart
