Yes it does need to be Trans. and it is. I couldn’t find any
reference to targets in the WY docs yet (still looking) so I’m unsure
how it would need to be formatted if it is indeed possible.
T.
On Sep 19, 2008, at 6:16 PM, DeltaDave wrote:
What HTML level have you set your page to - does it not have to be
Transitional for this to work?
Hi Todd I could be wrong but I don’t think longtext supports target blank
but to make sure I would drop a line to Johannes at OBD just to confirm either way.
Max, I’ll do just that. It would seem a simple thing though, doesn’t it?
blank
confirm either way.
then the link will default to the same window. Apparently there’s no way to strong-arm WY into using target=“_blank”. That’s the tradeoff. My issue was that this is how I wanted to format it and have it open a new window. No such luck.
On Sep 20, 2008, at 6:27 PM, DeltaDave wrote:
Hi Max and Todd
On the forum this answer isn’t clear - could you post it in a code block so I can see it please.
Very strange, I don’t know why it’s happening. However, this page
from the WY manual illustrates exactly what I was referring to,
<http://www.obdev.at/resources/webyep/documentation/
WebYep_Documentation_1.3.0/reference/long-text.html>.
On Sep 20, 2008, at 7:48 PM, DeltaDave wrote:
Hi Todd
I dont know if I am being dense or what but when I use your first
example (copied from the forum)
For anyone following the target_blank thread regarding links in long text items apparently it is possible (according to obdev) to override the default behavior when formatting a link like this:
We both agreed that a link like http://www.somesite.com/myfolder/index.html was far too clunky just for a new page to open and as he says it is really easy to change the webyep.php file so that the normal link behaviour of
