Hi julie
yes you can.
What webyep does is insert certain code in place of text and when you unlock the page you are able to add text within those bits of webyep code, so it doesn’t matter that the code is within an accordion.
Hi julie
yes you can.
If I put a slideshow up - could someone change the pix in the slide show w webyep?
same question for a lightbox .
Thank you -
J
On Feb 9, 2010, at 2:09 AM, max wrote:
Hi julie
yes you can.
