When files lose their creator icon
I remember this happening years ago when all my Quark files lost their creator icon. Now a lot of my FreehandMX files have lost theirs. Can’t remember the solution - can anyone oblige??
Kryters
It could be several different things. You might need to rebuild the desktop, but first try relaunching the Finder.
Either Quit (Finder menu>Quit) or if you don’t have that in the menu go to Force Quit (Command-Option-Escape) and relaunch Finder.
There’s a program called QuickChange that might help fix that problem:
http://www.versiontracker.com/dyn/moreinfo/macosx/11494
Thanks Paul, rebuilding Desktop not possible or necessary with OSX apparently.
Thanks Joe I’ll try that.
K.
