I have an HTML box with the start item and immediately after the Heading item. A return and a Table entered for the Image item and the text item. Another return outside the table and a rule inserted and another return end item inserted.
I would just like some uniform spacing between the items.
Try as I might, I can’t get the spacing right - the 1st item looks OK but on 2 and 3 heading is tight on top of picture.
Just can’t get to the bottom of this. I have now simplified the layout to try fixing the space issue but now the long tesx box will not accept text style. It is applied to the box but not showing up as Helvetica!
I think you may have to style that separately, making sure to add a space before and after the box.
