I’m afraid not. To create the shop you just install the script and add your products, then If you want to style the shop you need to look in the CSS files and adjust as required to change fonts, font colours, div sizes, link colours etc, etc.
That not to say you can’t use Freeway to create the graphics you use for the shop.
David Owen :: Freeway Friendly Web hosting and Domains ::
A secondary question for all:
Any Recomendations for a css and an HTML editor to change the colors
etc and the txt that they have?
Thank you
J
Sent from my iPhone
for the shop.
You might want to look at Coda (from Panic) which incorporates a nice
CSS editor along with an industrial-strength code editor. Another app
on these lines is Espresso (from MacRabbit) which does the same thing,
more or less. MacRabbit already makes one of the finest CSS editors –
CSSEdit – which is a real workhorse.
On Nov 27, 2009, at 11:12 AM, Julie wrote:
Thank you David.
Any Recomendations for a css and an HTML editor to change the colors etc and the txt that they have?
Thank you
J
Sent from my iPhone
Thank you
J
Sent from my iPhone
On Nov 27, 2009, at 4:17, David Owen <email@hidden
use for the shop.
On 26 Nov 2009, 8:44 pm, swimmer35 wrote:
I am learning building an ecommerce site w zen-cart. Is there a way to build a template for zen-cart in freeway?
I did a Zencart site for a friend, finding all the files to change is a bit of a nightmare.
there are folders inside folders all containing files named the same thing so you never know which file to alter, if you update Zencart it overwrites all your changes unless you save them one of 7 specific folders and back it up.
It works but I really hated it, the whole thing is designed by masochists…
there is a new version in the works but it was promised to appear 10 months ago.
my advice is to buy a good book, I bought this one and it does help the steep learning curve
I looked at some clips of the book - maybe I will invest…
is there any other e-commerce cart that is easier to do? She wants to
upload it herself instead of paying someone to update.
we are looking at 50 products ( plus variations)
is it better to do mals? (but can she upload wo freeway?)
I will take any ANY suggestions or shopping carts etc!! Thank you
masochists…
months ago.
i know it is an old topic, so forgive me please, but i have just completed my 3 zencart shop together with my website. its fun, not very easy but you can do it!
it looks the great and look on both site and cart are the same!
i think i can even give people some advise for it so when needed, don’t hessitate, i can finaly be of help to!
Eus
Eus
