I had a quick play with the standard Show/Hide Actions, and found that
while you can easily make things appear and disappear, there’s a hitch
to this layout. Getting them to appear directly over top of the
trigger element is easy, getting them to hide again afterward is
nearly impossible, particularly if you have more than one trigger
element “under” the zoomed image.
You can build a similar effect using the Protaculous Action, but it
takes a little work.
###Page
Apply Protaculous to the page, select scriptaculous-packed from the
Library menu, and enter the following in the top Function Body:
$$('div.zoom').invoke('hide');
That hides any element on the page that has class=“zoom” applied to it.
###Zoom Item
Draw a large graphics box, import your zoomed image into it, and
select Item / Extended from the main menu. Click on the DIV segment of
the dialog, click New, and enter
in the dialog.
Make note of the name that Freeway has given this element (left-most
pane of the Inspector) – item4 in this example.
Apply the Observer Action (part of Protaculous) to the zoomed image,
set the library to scriptactulous-packed, set the event to ‘click’,
and in the Function Body, enter the following:
this.fade();
###Trigger Element
Draw a small graphics box elsewhere on your page, fill it with your
thumbnail image, apply Observer to it, set the library to
scriptaculous-packed, set the event to ‘click’ and in the Function
$('item4').appear();
Send the trigger element to back, and position it under your zoomed
image. Both elements must be layers, and neither may be a child of the
other, or the effect will fail.
Preview or Preview in a browser, and when the page first loads, the
only thing you will see will be the trigger element. When you click
it, the zoom image will fade up (not quite as sexy as a real zoom, but
a good analogue). When you click the zoomed image, it will fade away.
On Feb 6, 2009, at 3:49 AM, macsterdam wrote:
thanks for the quick reply, much appreciated.
any idea how to implement this in freeway? or don’t I need all that
code?
