Font Features are another, arguably better way of accessing special characters. Font features can be found in GX fonts (also known as AAT fonts) and OpenType fonts. Both formats use ‘glyph substitution’ to replace standard letters with special characters.
To access font features, open the Font Panel (Command-T) and click the ‘Gear’ icon at the bottom, left-hand corner of the panel. In the menu that appears, choose ‘Typography’. The ‘Typography’ palette that appears lists the available features in the current font. Helvetica has one feature— ‘Common Ligatures’, but Apple Chancery, Hoefler Text, Zapfino have lots of extra features.
GX fonts are Mac only, so Windows users will see gibberish. Special characters can always be converted to outlines and the document saved as a PDF, which should display correctly in the Windows version of Acrobat Reader. PDFs with ‘live’ GX special characters may render correctly in Windows, but I’ve not tested this.
OpenType features work on both platforms, but you’ll need a font editor to create them. The industry standard FontLab costs serious money.
Simple GX features are straightforward to create and you can do it for free. Features are appended to TrueType fonts with a small text file, called a Morph Input File (or MIF). The instructions in the MIF ‘map’ or link special characters to standard letters.
I’ve never needed to typeset languages and don’t know Greek, but I did a test with the font Tahoma, which includes the glyphs for several languages including Greek. I mapped ‘Gamma’ to the letter ‘g’, Theta’ to ‘t’, etc, installed the font and the Greek characters displayed correctly in Intaglio, Text Edit and several other programs that support the OSX text engine.
Once you’ve got this working with one font, it’s straightforward to apply the procedure to other fonts. For example, the thousands of symbols in the Apple Symbols font include pointed fingers, arrows, audio, Braille and box connectors. Accessing the characters could be simplified by creating special categories and mapping to standard keys. It’s non-standard, but much easier than remembering Unicodes.
The procedure for creating font features is convoluted. It involves using several Classic Mac apps and a text editor. If you’d like me to go into more detail, please let me know.
Intaglio mailing list
