Problem 1 is that when I narrow down the width of the page in a browser, the thumbnails for the gallery spill out of their holding box and across to the right. Pretty sure I just have one of the settings wrong, but I’ve just spent 2 hours plating with the Inline Div and the WYGallery settings and got nowhere!
Secondly, I have Lightbox installed in the webyep-system > program > opt folder, which works fine, except that 2 images are missing when I go to the slideshow in the browser - close label.gif and loading.gif. Both are there in the lightbox > images folder, so not at all sure where to go on this one.
As far as the close button goes, here’s an excerpt from page 36 of the WebYep Action Documentation from Max:
For the configuration of the Lightbox script, please follow the instructions given on its web site - see the link above. You might for example want to edit the file webyep-system/program/opt/lightbox/js/lightbox.js to adapt the paths to the image files used by Lightbox for the “close” and “loading” images to:
var fileLoadingImage = "/webyep-system/program/opt/lightbox/images/loading.gif";
var fileBottomNavCloseImage = "/webyep-system/program/opt/lightbox/images/close.gif";
Alternativly you could just move or make a copy of the images folder inside the lightbox folder and place it next to your resources and css, folders that freeway creates on publish. This will have the same effect as adjusting the lightbox script.
Thanks Caleb, I actually did the 2nd suggestion (copying the images folder) yesterday, and this got the images showing, but for some reason, the close button doesn’t work.
As I mentioned to Max in my previous reply, I probably won’t get a chance to jump on this until next week now, but thanks everyone for the help & suggestions.
On 2 Aug 2013, at 06:37, Caleb Grove wrote:
Trev,
var fileLoadingImage = “/webyep-system/program/opt/lightbox/images/loading.gif”;
var fileBottomNavCloseImage = “/webyep-system/program/opt/lightbox/images/close.gif”;
