For anyone who wishes they could paste: single words, sentences or even whole paragraphs of latin text inside a Freeway.
If that’s that sounds like the sort of thing that you were looking for then you can do it using a really handy tool called LittleIpsum and you can get it here http://littleipsum.com/
Whats great about this over other Lipsum generators is that it works perfectly with Freeway, photoshop and just about any other program, you don’t need to navigate/use a browsers to generate the text, Its always available in your macs top bar and bets of all its… FREE
To try it in Freeway just install the LittleIpsum application (you will need to be running 10.5)
Then once it’s installed launch Freeway
Create a new page and draw div or a table.
Go to the mac top bar and click on the L symbol, This reveals a dropdown that shows pictorily the quantity of text which you can choose from.
Then once you have made your choice by clicking on the desired quantity, click inside the freeway div/table and paste cmd-v
The chosen quantity of text should now be pasted within the div…
