A little help, please
I assume the following is set through php.ini? If so, how do I know what value to use?
!IMPORTANT: if you are using htaccess protection, make sure your $GLOBALS PHP_AUTH_USER/PHP_AUTH_USER are defined in your webserver config
https://xiiro.com
dynamo mailing list
