A variety of issues
Good Evening,
I am redoing a site due to some tech issues (too many font styles - causing the 2 front boxes not to align, etc)
I am doing as suggested by Keith and Joe at softpress - rebuilding the site - making the fonts in the styles menu.
It seems to be working much better.
http://www.grassrootsweb.net/jen
but I have some issues.
  1. If you look at the front page: box on rt I want to have that box that says call us in the center bottom:
    I have tried the tabs (no go) , changing the margin (but that moves all the tabs over) in the inspector.
    How can i do that if it is inbedded in the HTML box?
  2. how do I change the color of the bullets?
  3. are the pictures on the front page blurry?
Thank you
Julie
box on rt I want to have that box that says call us in the center bottom: I have tried the tabs
It would appear that you have made this item inline and part of your list. Try cutting it from the page. Insert a para and make sure it is not indented as part of the list and then paste it back inline.
To style/colour the bullets here is a method from Tim.
To style your bullets in Freeway 5 or 5.5;
  1. Select Edit/ Styles
  2. Create a new style with li (list item) in the tag field and nothing in the name field
  3. Select color from the character section and add the bullet color you want
  4. OK the dialog and see your bullets in glorious color!
There other ways but this is straightforward enough to do.
As to your images - do you mean the special offer bit?
I think… They werent specific
That picture is part of the big picture.
Thank you for the other solutions. I will work on them in a few.
Julie
Sent from my iPhone
How did you create it?
I created it in Photoshop… I had the main picture, placed that one did a bit of size change and also perspective to have that small to large angle look like the tv
J
But did you have a large file that you created and added the ‘special offers’ bit before importing in FW or were you working from a presized file (smaller)
If the latter then ideally you should be working with a Photoshop psd at original resolutions, add your layers etc and then import into FW for resizing etc.
I am working w the original res. But had to reduce the specials to have it fit the TV and get the angle etc.
WHen i transfer it to FW i have to resize - fit to box.
J
I went back to the original file, am adding the orange graphic. I will have to resize this a bit dt me doing the special affects.
Is there a better format to save the larger (original) in for FW to keep the clarity?
Thank you
J
Photoshop PSD
