Add audio to exhibeo
Can I attach an MP3 audio file to an exhibeo xw component file?
Grateful for any info
Hi Tony,
Can you expand on what it is you’re trying to do? Are you trying to create a slideshow with a background soundtrack, or do you want each slide to have its own soundtrack, or something else?
Hi Jeremy
Thanks for the prompt reply
I would like an xwcomponent slideshow with a bg soundtrack.
As it is now, I create a page that includes an xwcomponent and a mp3 where both play when opened.
For example, open https://seeworthybirds.com/arizona-birds.html and click on the Scenic Arizona button to see how I have set this up. This works ok, but I thought it would be more better if one could just create a link that opens and plays an xwcomponent with an mp3 embedded (?) in the slide show.
As I have created three xwcomponents for Costa Rica, I think it would seem more efficient to just open them w/o having to create three separate page analogous to how I have done for Arizona and several other places.
Is this mostly clear?
tony castro
https://seeworthybirds.com/seeworthybirds.html
Hi Tony,
Thanks for that example.
Exhibeo doesn’t currently support adding a background soundtrack, although I can see that might be a nice feature for slideshow galleries.
I notice that the slideshow starts automatically on your page, but the soundtrack doesn’t, and I’m not sure that it’s possible to have a background soundtrack play automatically on all browsers. Some browsers will block this from happening.
Hi Jeremy
Thanks again for your prompt response
Yes… a background soundtrack for exhibeo galleries would be a nice feature, but the user should have the option to turn it off.
Also, it would be nice to be able to reduce font size for titles and captions for viewing on an iPhone, but maybe this is asking for too much.
The soundtrack on scenic Arizona is set to auto play and does start automatically for me. I assume you are seeing it and can turn it on.
Thanks again for all your help
Tony Castro
Yes, I can turn it on.
Safari 26 for Mac has an autoplay setting that can be configured to allow websites to Allow All Auto-Play, Stop Media with Sound, or Never Autoplay. [Settings > Websites > Auto-Play]
I think Safari 26 for iOS defaults to Stop Media with Sound, and I don’t think there is a way to configure this.
Firefox for Mac has a similar setting.
A post was split to a new topic: Changing the font size of titles and captions in the Slide theme
