I applied Tim Plumb’s Add Meta Tags action. Everything works fine.
When I looked at the Source Code, I see that the meta tags are not up at the top, right below the “GENERATOR” tag. When I apply the tags manually, they are right below.
Does it matter to the search engines where in the code these tags are? (I realize the diminishing importance of the tags already, so we can avoid that discussion.)
