Add rule above a paragraph [style]
Hi,
I’d like to add a rule above a paragraph and add it to the style sheet.
I’ guessing it needs to be added to the Extended, but don’t know how?
Best wishes Peter
Peter Tucker, Oxford UK email@hidden
Hi Peter,
Try this;
  1. Choose Edit/ Styles
  2. Select or create your chosen style for the text
  3. Click the extended button
  4. Click the New… button
  5. In the fields enter
    Value: 1px solid #666666
  6. Click the OK button
  7. Repeat steps 4 to 6 with the following values;
    Value: 10px
Now when you apply this style to your text and preview you should see
a 1 pixel grey line above the body of text. Adjust the colour in step
5 for your chosen hex colour and the offset between the text and the
rule in step 7.
sheet.
FreewayActions.com - Freeware and commercial actions for Freeway
Express & Pro.
Spam.
http://www.freewayactions.com
Many thanks Tim exactly what I needed. Although I tightened-up the padding and made some other changes too: http://oxmug.org ;~}}
Sorry to be dumb, but I guess is a good list of these type of text options available on the web somewhere?
Peter Tucker, Oxford UK - but mobile somewhere
On 14 Sep 2010, at 09:55, Tim Plumb email@hidden wrote:
Hi Peter,
Try this;
    Value: 10px
Now when you apply this style to your text and preview you should see a 1 pixel grey line above the body of text. Adjust the colour in step 5 for your chosen hex colour and the offset between the text and the rule in step 7.
FreewayActions.com - Freeware and commercial actions for Freeway Express & Pro.
Hi Peter,
The W3C have their box model spec page - Box model
  • that outlines some of the more common styling you would want to
    add such ad padding and borders. It’s a little dry but will get you
    started on the styling options.
Express & Pro.
Spam.
How would you get the rule to be just the length of the text rather than the whole para width?
