- Select the graphic in Freeway that you want to attach the pop up to.
- Go to the Item menu and select "Extended"
- In the "Extended Attributes for <IMG>" dialog that appear, click on New and enter the following:
in Name type "title" (without quotes)
in Value put [whatever text you want] - Close the dialog
A "tooltip" is descriptive text that appears in a box when an image or graphic is hovered over with the mouse. To add these you need to:
