Quite often a normal cable of a pair of stereo jack plugs to a single
plug connector will do the trick of getting it into the Mac, then
there are a variety of programmes to actually record the broadcast.
An easier option might be the internet broadcast, then AudioHijack or
AudioRecorder can ‘hijack’ your web browser and record the stream. I
think both are fairly cheap, but make sure you don’t just go with the
demo version as I think they only give you 10 minutes or so of
recording before it adds in white noise.
On 22 Jun 2011, at 14:02, Julie Maxwell Allen wrote:
Good morning all,
I am sorry for another way off topic
My local radio station is playing the last Springsteen / clarence
Clemons (rest in peace) concert on friday night. Happened to take
place up here.
Is there a way to record it on my mac or through connections to my
stereo?
I was at the concert and would love to have it.
This radio station also streams live on the web too.
to hook my stereo to my mac to play my itunes through my stereo. can this be used?
I will check into the 2 programs also.
I do appreciate it.
Julie
On Jun 22, 2011, at 9:19 AM, Trevor Reaveley wrote:
Quite often a normal cable of a pair of stereo jack plugs to a single plug connector will do the trick of getting it into the Mac, then there are a variety of programmes to actually record the broadcast.
An easier option might be the internet broadcast, then AudioHijack or AudioRecorder can ‘hijack’ your web browser and record the stream. I think both are fairly cheap, but make sure you don’t just go with the demo version as I think they only give you 10 minutes or so of recording before it adds in white noise.
Good morning all,
My local radio station is playing the last Springsteen / clarence Clemons (rest in peace) concert on friday night. Happened to take place up here.
Is there a way to record it on my mac or through connections to my stereo?
That cable should be fine Julie, it’s just what programme to use once
it’s into the Mac, I use Amadeus which is a good all-round audio
editor and quite cheap. I still think the easiest for you might be one
of the 2 programmes mentioned earlier.
Good Luck & happy hunting. Shame about Clarence.
can this be used?
I do appreciate it.
Julie
broadcast.
Good morning all,
place up here.
stereo?
Thank you… I can plug it into my speaker jack then. ok.
I will check that out to.
I did look into them and they seem great. so I probably will go that way.
Thank you again.
it is a shame.
J
On Jun 22, 2011, at 9:34 AM, Trevor Reaveley wrote:
That cable should be fine Julie, it’s just what programme to use once it’s into the Mac, I use Amadeus which is a good all-round audio editor and quite cheap. I still think the easiest for you might be one of the 2 programmes mentioned earlier.
I do appreciate it.
Julie
Good morning all,
If you don’t want to pay for a full feature audio recording application, search of Audacity. It’s free and open source, and is often bundled with audio hardware.
I use it here to record and edit stuff. It’s a bit clunky in places, but works pretty well.
Heather, I tried the audacity and recorded as I played the station on the web. It sounded very tinny. also I am seeing that I have to have the volume completely up so that the built in microphone will pick it up. I will continue to play with it to stop that. any tips?
Thank you
J
On 22 Jun 2011, at 15:12, Julie Maxwell Allen wrote:
any tips?
Hmm. Sounds like the output from your source isn’t adequate. Is there any way to get a line output (phono or RCA type sockets) which can go directly into the Mac’s mic socket?
Also, you may need to adjust the input levels on the Mac. You can do that through the Sound control panel in System Preferences. Another thing to watch out for is Audio Midi Setup (find it in Applications > Utilities).
I wish garageband would do that - but only works with the built in mic.
Thank you so much! Now I am ready for friday
J
any tips?
that worked perfectly! THe concert sounds awesome!! Thank you so much!
I changed the external mic to using the mic socket.
I just have to edit out the commercials etc.
Julie
any tips?
