.ai, .png or whatever not showing well in Freeway Pro 5
what`s a bit nervy is all about the discussion of output of the graphic programms.
You never loose a word of the settings in freeway!!!
A proposal: Leave it as .ai
Make four graphic items and import one and the same .ai into it (of course uncheck pass through!!!)
Set the first box jpeg 75%
Set the second box jpeg 100%
Set the third box gif
Set the forth box png millions
Share your result via link.
After all we all can really discuss about some losses and fuzzy and all. A lot of things are things of attitude, standpoints and philosophy - but not of really lifetime.
And if there is going something wrong I´m sure there will be next step.
So tease me with your link
Ok Thomas, I’ve done as you suggested and you may see the results at http://www.sheloep.nl/test/
Thanks for all your help and suggestions.
I think I should be happy with the last 2 results… the third .ai into .gif and the last one into.png.
I’m glad I met you guys!
