Hi Marcus,
the complete overview can be found either at:
http://kimmich-dm.de/wordpress/?cat=10
or via
http://freewaycast.com/
The casts that you mentioned are anyway the lower 6 ones but they should be complete. I know, that this section is a 'lil mess that I have to clean out but haven’t had time to do yet - apologize. I can’t explain why they should miss at the moment.
If there are any further questions, don’t hesitate to contact me (however it’s late that night)
Great. They are complete.
Thank you very much, Thomas
Marcus
The dimensions 1633 × 843 I did was because I wanted the slideshow which have 960 x 484 to fit inside the waves.
Its not the dimensions of the image that are the problem but the file size of 1.6Mb
As you have seen from your other images you can reduce the quality considerably and so reduce the file size to a far more sensible weight. Remember the focus is the video - not what surrounds it.
Thank you, David.
Tomorrow I will take care of this and post it here when I have this problem and the overlapping thing done.
Have a nice weekend
Marcus
Sorry guys, but I didn’t have the time yet to work on any of the options you gave me .
The problem is that I need the video/slideshow to be under the wave-frame.png. The wave is a frame and If I use the wave-frame.png as a background to avoid the overlap problem how do I put this video under it? I couldn’t find a solution yet…not even with the RPL.
I thought that maybe, I could cut part of the wave-frame.png that fits inside the 960 grid and that would work if I adjust the position but o the other hand I could not tile the background horizontally, neither vertically because I don’t want the wave to repeat…
I hope I can make myself clear in my explanation. Any ideas?
ps: Thomas, I already subscribed to the screencasts and will take a time everyday to learn this properly even though I understand its a steep learning curve.
best regards,
Marcus
Hi Marcus,
I tried your needs if it is possible to solve it in “inline” and came up that it is - however not that easy.
I want to be prepared, so this is the link to my results yet (please note all static):
http://kimmich-dm.de/box-in-box-model/Testings/marcus-index.html
Try this, cause I think it matches much better what you are after (hopefully).
Hi Thomas, yes.
That worked! I’ve just tried in my iPhone and it worked nicely centered. On the other hand it in an Android tablet I have the wave doesn’t appear, but’s I think it’s a matter of little adjustments and hats the way I have to follow though
Marcus
Thomas,
again,
thank you very much for taking your time to try this in inline-box model. I will definitely work while I learn more the inline-bom model at the same time
cheers,
Marcus
Hey Thomas,
I hope you had a nice weekend.
One question: Do you believe you could send me this inline sample template you did with my page? So I can study it meticulously?
Please let me know
Many thanks in advance
Marcus
It’s on its way.
Thank you very much, Thomas!!
Marcus
Hello friends!
I found a temporary way to get the idea I wanted in absolute / layer mode, without overlapping items problem I had before.
I am seriously interested in learning the Box-in-Box-Model but I have been really busy lately in many other projects and have to finish them first.
Here it is:
http://www.plusartgraphics.com/test/osb4/index.html
many thanks,
Marcus
