HI again,
I have just finished designing a site and the client then decided that he wanted music running throughout the entire site.
The only way I could think of doing this was putting the whole site through an iFrame and have the music box on the site index.
However, when doing this, the text on the site is going blurry and pixelated?
This is the site which is embedded into an iFrame:
http://www.sct-photography.co.uk/rt/site
This is the site with the music box:
On the …rt/site I have set the background to ‘none’ because I wanted to use the background from the …/rt site so that it would be full screen and also resize to the browser.
Is there anything that can be done to resolve this?
Thanks in advanced,
Seb
Has anybody else experienced this issue?
Seb
Shane1
(Shane)
June 18, 2011, 9:03pm
#3
I saw the same thing when I was testing it too.
I suspect that this is because you are using graphic text with no background.
If you do that then the anti-alias settings wont know what colour to anti-alias against leading to fuzzy edges.
You will have to manually sellct a background colour to AA against to resolve this.
Hi David,
Thank you very much! It was indeed the aliasing that was causing the problem.
Seb
