Another upload problem
When I upload the site, it do upload close to 3000 photos each time… this do of course take awhile, any way to avoid this, and just upload the actual correction/file???
Marit
Can you let us know which version of Freeway you are using?
Marit
the most recent - the pro version, and it seems that is the galleries that do upload all the photos each time, have all those in a separate folder called galleries
Marit
Hmm, they shouldn’t be re-uploading each time. Are you making any changes to the pages containing the galleries?
Marit
No, the last change I did, was a small spelling error - did not do anything to any photos… and it’s of course annoying when it takes for ever to correct this
Marit
Can you just run a quick test for me - try uploading again now without making any changes. Does the whole site upload? If so, try going to the Edit dialog (in the Page menu) and choosing Resample All to see if that helps.
Marit
Did the upload, still the same. And I might be stupid, but is not able to find edit, in the page menu :frowning:
Sorry, meant Resources in the Edit menu! Been a long day :slight_smile: Open the Edit menu, choose Resources, hit Resample All. It will mark everything for republish but may fix it for subsequent uploads.
Will try that… and since I am located in Norway - we are completely different time zones…
Nah, that did not help either… still uploads all the photos.
Ok, I’ll do some investigation. Apologies for the inconvenience.
Thanks, that would be great. I would really like to re-do all my pages witch contains lots of photos (most of them do) into galleries… think that is nicer. Then visitors can decide witch photos to see larger, and it will for sure shorten the lenght of each page.
Thanks again
Marit
