Todd1
(Todd)
December 29, 2012, 1:59am
1
I just used Cocktail to clean the System caches (which I’ve done dozens of times before without issue) and now when I try to run MAMP Pro I get this alert:
The built in Apache is active which can cause a port conflict with at least one of your virtual hosts.
It's recommended either to choose a port different than 80 or to stop the built in Apache.
Using Terminal I’ve already tried stopping and restarting Apache. No go.
I haven’t changed any settings in MAMP Pro or anywhere else so I’m stumped.
MAMP port settings:
Apache: 80
MySQL: 3306
SSL: 443
10.8.2
dynamo mailing list
Todd1
(Todd)
December 29, 2012, 3:31am
2
Fixed it. After a reboot I ran this command one more time just to be sure:
sudo apachectl stop
dynamo mailing list
waltd
(Walter Davis)
December 29, 2012, 6:30pm
3
What version of Apache are you running in the system? Shouldn’t that be apache2ctl?
sudo apachectl stop
dynamo mailing list
dynamo mailing list
Todd1
(Todd)
December 30, 2012, 2:24am
4
Apache 2.0.
I found the solution online but you’re probably right, it should have been apache2ctl instead. Why it worked I don’t know.
dynamo mailing list
waltd
(Walter Davis)
December 30, 2012, 2:26am
5
They may have added an alias to the real method so they didn’t have to rewrite all the documentation.
On Dec 29, 2012, at 9:24 PM, Todd wrote:
Apache 2.0.
dynamo mailing list
dynamo mailing list
