I have sections of sites that basically display database tables. I
use a piece of script that outputs fields in a form based on the
field types as defined in the database into s. Long varchars are
wide; short ones are narrow, enums are pop-ups/checkbox/radio if
modifiable etc. In text circumstances where the field a modifiable it
is output into an within its . The length/width of the
input box being determined from the database definitions, currently
by including the deprecated/removed width= attribute.
I’m re-doing this for newer versions of HTML and so want to drop the
width attribute. Other than just changing the attribute to
style=“width:xxx” is there a better way to add widths at a ‘further
out’ level when the required width is determined dynamically at the
same time as the content?
Also, does anyone know where there is a list of all modern style
attributes that are applicable to specific tags? w3schools used to do
it, but they’ve dumbed it all down now the possibilities are much
greater. For example I expect that the ‘width’ style for an
is no longer “width”, but I can’t find out what the proper term now
is.
www.ivdcs.co.uk
