I’m trying to put an audio player on one of the sites I’m designing, so I can upload some of the band’s tracks for people to play. I’ve downloaded one from a really cool (if you like Flash) site, but the instructions are minimal. It just gives you an html page and tells you to paste the page source-code into your webpage. I’ve tried doing this as an html markup item, and all I get is this: http://www.thievesinsuits.co.uk/tis-audiovisual.html
As you can see there’s a box with no player in it.
I’ve also tried putting the code in the html markup option in every part of the markup (Before ) etc but still no joy. There are files which you need to upload to the server, and I’ve put them in the root directory, without any effect.
The website I downloaded this stuff from is at:
Any help from you experienced coders out there would be greatly appreciated.
Thanks for your reply. I discovered what I was doing wrong - had the
mp3 files in the wrong place on my server. Now all is working fine.
Took me all morning but got there in the end!
